Cannot get into the truck
126,000 MILES • 4.6L • 6 CYL • AUTOMATIC
BENNYKENT
Just bought this car for a couple of days the truck would not open.now I'm in the process of getting the back seat out. any suggestions?
Nov 26, 2019 at 4:38 AM
STEVE W.
  • 15,385 POSTS
The fun part of electronic trunk releases. There is a way to open the trunk from outside. First you need to remove the license plate, Then you drill a hole through the trunk 4 inches directly above the trunk latch. Now you can reach in with a screwdriver and release the latch. Video on the drilling method. https://www.youtube.com/watch?v=RAmJ8YhWt4o
If this is a US car with the plastic plate mounts the mounting holes are in a position where you can use a hooked wire (coat hanger works) to reach in and do the same. If you remove the plastic inserts on both sides you can use one for a flashlight while the other in used to fish for the latch. It isn't fun but it isn't real hard either way.
Nov 26, 2019 at 5:55 AM
