my xj6 jag sweats like a pig. even if the vehicle has not been run for a month water will condense on the inside of the car every night.
Nov 28, 2008 at 5:46 AM
JAMES W.
✓Experienced Mechanic
Check the drain holes in the bottom of the doors. Trapped water in there and a wet trunk will cause this. Also, check the a/c evaporator drains on either side of the console up next to the firewall to make sure they are not plugged. Hope this helps.
Dec 2, 2008 at 10:58 AM
