So my driver front window is stuck mid way. Can't get it up. I can hear the motor running. I opened door trim and try to manually push up the plastic clamp that holds the glass, but doesn't budge. I figure the regulator is bad. I hardly use the car so don't want to replace the part. All I want to do is get the window up and keep it that way. I will keep it closed forever. it is 98 mercury mystique. Appreciate the help. Thanks.
Aug 26, 2016 at 5:49 AM
