Engine has no spark?
35,760 MILES • 1.4L • 4 CYL • 2WD • MANUAL
CHARLES MOLIMISI
The car doesn't crank with the key and there's no spark.
Feb 19, 2020 at 3:15 AM
  • 110,248 POSTS
The vehicle isn't offered in the US, but I will try to help.
If you have no spark or starter engagement, have you checked for ignition or starter fuse issues in the under hood fuse/relay box? Do all other electrical components work? Have you checked the starter for power?
You indicate you are a mechanic, so I'm not sure what to add that will help you. However, here is a link that explains how to check for power at the starter. I hope it helps.
Feb 19, 2020 at 10:44 AM
JURGENS
There is no spark at the plugs on my opel corsa 1.3 lite please could you help?
May 19, 2021 at 7:27 AM (Merged)
  • 75,988 POSTS
To me it sounds like you have a crankshaft angle sensor that needs to be replaced from what you have described. Here is a guide that will give you an idea of what you are in for when doing the job Your car will be a little different but you will get the idea.
Cheers
JURGENS
I wasn't sure what was causing the problem but I followed your suggestion and replace the cranks sensor and BAM! the car started and works great. Thanks 2Carpros I love this site.
  • 55,628 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
JOHAN HALGRYN
Good day, i am sitting with a problem my Opel Kadett does not have spark just after they replaced head gasket.
Please can you give me some advise?
  • 110,248 POSTS
I'm not real familiar with the vehicle because it isn't offered in the US. However, I try my best to help.
First, the most common cause of having a no spark condition is a faulty crankshaft position sensor. Now, since there was a lot of work just done, something could have been left disconnected.
Here is a link that explains in general how a crankshaft position sensor is replaced. Take a look through it and then try to locate the one on your vehicle.
I'm not sure what year your vehicle is, but if it is newer than a 1995, it should have an OBD2 diagnostic system. If it does and you have a live data scan tool, plug the scanner in and crank the engine. If the sensor is bad, in most cases you will not have an RPM signal.
