Can't bleed the brakes oh the driver side.
214,499 MILES • 1.5L • 4 CYL • AUTOMATIC
JUSTMESAGUIRRE
Have changed brakes twice within the last month and a half and the rotor the last time & brakes are grinding again & now the brakes will lock up, but only on the one side?
Jan 20, 2016 at 6:54 AM
CARADIODOC
  • 34,413 POSTS
You should have noticed a brake has been dragging. Also, if you check by the affected wheel, you should find it's really hot. First consider if it's possible the brake fluid has been contaminated with a petroleum product like engine oil, transmission fluid, power steering fluid, penetrating oil, or axle grease. Even one drop of any of those will be catastrophic.
If contaminated brake fluid is not a good suspect, the next time a brake locks up, stop on a slight incline, shift to neutral, place a block about a foot downhill from one tire so you won't look funny chasing after the car, then loosen a steel line at the master cylinder. Most likely that will not cause the locked brake to release. Next, crawl underneath the car and open the bleeder screw on the caliper. If that lets the brake release, suspect the rubber flex hose.
Jan 20, 2016 at 7:08 AM
