Transmission does not work in drive
175,264 MILES • 3.8L • V6 • TURBO • AUTOMATIC
JALISA22
I was driving on the highway and when I stopped at the red light it was find but by the time it turned green I was pushing a gas and it did not go anywhere in D. But when I put it in R it works fine with no problem. Also, second and third also worked. so my drive went out so I had to ride home in third which was like a half mile from where it was messing up at. Car is supercharged.
Mar 18, 2018 at 9:49 AM
  • 55,673 POSTS
It sounds like you are low on fluid have you checked it? Also do you have any check engine lights on?
Here are two guides to help us fix the problem.
and
Please run down these guides and report back
Cheers, Ken
Mar 21, 2018 at 3:33 AM
