1998 Buick Regal Transmission
74,000 MILES • 6 CYL • FWD • AUTOMATIC
AZRAM63
After driving around for a while when the car is hot the transmission slips. When I come to a stop it stays in high gear and I have to manually shift down and back up again. It also wont go into O/D. It only does this intermittently. After it's turned off for a while it stops or on short trips it works fine.
Apr 23, 2009 at 7:40 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Has check engine light come on? Has fluid and filter ever been changed? As I understand O.K. cold and happens hot intermittenly?
Let me know
Thanks for donate
Apr 23, 2009 at 9:14 AM
AZRAM63
The check engine light has not come on. I had the fluid changed at around 46,000 mi, I think the filter too but am not sure. It only has happened when the car is hot and intermittently.
Apr 24, 2009 at 1:09 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Need to have trans scaned to see if it maybe a faulty shift solenoid. The hanging in high and the intermittent occurance tells me not a clutch or hard parts issue.
Apr 26, 2009 at 5:57 AM
