HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
L300
Engine
Camshaft
Camshaft Sensor
Replace/Remove
SPONSORED LINKS
Camshaft position sensor
PREV
1
2
NEXT
JESSICA 83
MEMBER
I know it has something to do with the throttle body
Friday, May 20th, 2016 AT 11:26 AM
JESSICA 83
MEMBER
I have tried to add the image 3 times and nothing has worked. Do u have a email I can possibly send to?
SPONSORED LINKS
Friday, May 20th, 2016 AT 11:31 AM
SATURNTECH9
MECHANIC
Are you using your cell phone to add the picture?
Friday, May 20th, 2016 AT 12:19 PM
SATURNTECH9
MECHANIC
I use my cell phone have no problem adding pics the picture I just attached is that what was tapped on?
Image (Click to make bigger)
Friday, May 20th, 2016 AT 1:39 PM
JESSICA 83
MEMBER
Yea I use my cell phone and the pics u have posted are blurry and hard to see
SPONSORED LINKS
Friday, May 20th, 2016 AT 2:15 PM
JESSICA 83
MEMBER
From looking on google and the pics I took its the actual throttle body
Friday, May 20th, 2016 AT 2:38 PM
SATURNTECH9
MECHANIC
The picture I posted to was clear enough to tell it was the throttle body. They must have put a used throttle body on it when they replaced it.
Friday, May 20th, 2016 AT 6:53 PM
SATURNTECH9
MECHANIC
They have a brand new one on eBay for 268 with a one year warranty.
Friday, May 20th, 2016 AT 6:58 PM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Camshaft Camshaft Sensor Replace/Remove Content
Timing Belt Marks For 3l V6 Need Diagram Or Whatever...
Timing Belt Marks For 3l V6 Need Diagram Or Whatever You Can Give Me
Asked by
Anonymous
1 ANSWER
2000
SATURN L300
GUIDE
Camshaft Position Sensor Replacement
Replacing an engine camshaft position sensor is a critical maintenance task that can restore your vehicle's performance and fuel efficiency. A faulty camshaft sensor can...
2003 Saturn L300 L300 Engine
Saturn L300 V6 100000 Miles. Driving Along And Suddenly Lost A Bunch Of Power. 2 Min Later Lost All Power And The Engine Would Hardly Idle....
Asked by
DIGGSBEE
1 ANSWER
2003
SATURN L300
Oil Change
Was Changing Oil On 2005 L300 Saturn Sedan V6 Front Wheel Drive Automatic. The Oil Cap Was On Too Tight And In Process Of Unscrewing It The...
Asked by
Mjmc
2005
SATURN L300
Thick Mixture Of Oil Only In Cooling System
Driving Noticed Steam, Was Not Overheating. Stopped Seem Bottom Driver Side Radiator Hose Sprung A Leak. It Was Not But About Two Miles...
Asked by
Timothy Foley
2002
SATURN L300
2001 Saturn L300 Takes Forever To Start
Mechanic Isn't Sure, Computer Says It Is Misfiring. Sometimes It Will Start 2nd Or 3rd Try Sometimes 30 Minutes Trying. The Part(throttle...
Asked by
AMEMUS
2001
SATURN L300
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Mercedes-Benz C230
How to Clear a Check Engine?
Topdon OBD2 Scanner Review - This thing rocks
Online car repair manuals
