cam shaft sensors
2007 GMC ACADIA
168,000 MILES • 3.7L • 4WD • AUTOMATIC
ANGIE DICKINSON
Will not start. Code says Cam shaft sensors.
It was running rough and I new the sensor needed changed.I finally stopped starting.
A auto shop said due to the miles I need a new engine.
Can I just have the sensors replaced? It has a 168,000 miles on engine.
Mar 29, 2019 at 4:10 AM
JOETECHPRO
  • 705 POSTS
Hey ANGIE DICKINSON,
If you can provide us with the codes you have stored?
Why did the shop tell you that you needed a new engine?
Was this a GMC dealer?
I see that there is a TSB for this vehicle regarding camshaft wear that can lead to cylinder head replacement, or a measure to repair the issue. Some can be fixed with programming the PCM.
They would need to carry out the checks to find out what you need first.
I would advise if you have the codes contact a GMC dealer, they should have the info on the checks and a quote depending on what you might need.
If you let us know the codes you have I will try and give you some more information.
Regards, Joe
Mar 29, 2019 at 4:57 AM
