Code 001161, Cam position solenoid valve?
87,100 MILES • 1.6L • 4 CYL • MANUAL
JACKIEJ77
I've done a pedal test, code 001161 showed up.
I recently had a replacement used engine, should this error be occurring? Or should it have been dealt with?
Jun 19, 2023 at 12:42 AM
BORIS K
  • 836 POSTS
P0011 61 Intake Camshaft Phasing Mechanics Range/Performance (Bank 1).
A good video:
https://youtu.be/81rbJWdmg14
and
https://youtu.be/AHweqZX4E14
Suggest to first check oil level and oil quality as this could affect the operation of either solenoid valve.
If in order you could swap left and right-side solenoids and see if fault moves to the exhaust side, giving P0014.
Cheers, Boris
Jun 19, 2023 at 2:36 AM
