Calipers replacement?
213,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AMYBELL614
  • 11 POSTS
I broke the bleeder valve, and I am trying to use extract it before replacing the entire caliper. Is it okay to spay it with some kind of rust penetrant? (The caliper is fully removed, and I will have to bleed all the brakes later)
Also, when cleaning the slide pins, I am replacing the slide pins and boots. Can I use brake clean inside where the pins go for a better clean and then lubricate once dry?
Dec 13, 2022 at 2:31 AM
  • 110,251 POSTS
Yes, and yes. When you clean with brake cleaner, take a rag on a screwdriver and clean all the dirt out. Just make sure it is clean and dry before lubricating and installing the new slide pins.
https://www.2carpros.com/articles/brake-caliper-replacement
Let me know if there is anything I can do to help.
Dec 13, 2022 at 2:25 PM
