2004 Toyota Camry Fuel Line or Brake line mount/strap/brack
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
DRMOODY
One of the brackets on the underside of the car has come loose. It is one of the brakets that mounts the, I believe fuel lines or brake lines, to the uderside of the car. What is that part called and where can I find one? Is that something I can do myself? It is a bracket that has three or four lines clipped into it and it is mounted to the underside of the car by one screw.
Sep 27, 2009 at 4:31 PM
STEVEW84
  • 673 POSTS
di you run something over? is the piece that is broke plastic? It is best to get it from the dealer.
Sep 28, 2009 at 1:23 PM
DRMOODY
Backed over a curb. I do not know what this piece is called.
Sep 28, 2009 at 2:08 PM
STEVEW84
  • 673 POSTS
is it plastic?
Sep 29, 2009 at 12:04 AM
