2005 Cadillac STS traction control
2005 CADILLAC STS
93,458 MILES • V8 • 4WD • AUTOMATIC
LEOMARTINEZ04
hi i bought a used cadillac sts 2005 over 3 months ago and it was working perfect. but one day when it was raining then traction control turn on and has been making my car go slow. i took itto the mechanic and the said the accelartor wasnt working when i bought the part and replace it it still was going slow. sometimes the traction control turns off but when your driving for a while it comes back on. do you know whats wrong with it?
Oct 17, 2010 at 11:41 PM
FACTORYJACK
  • 4,159 POSTS
If the traction light is coming on, it should be setting a code. If it is setting the same code as before the APP was replaced, then it may be a related circuit fault. If you have that code #, reply to post and I may be able to offer some suggestions. The code will narrow down the possibilities, as they are numerous.
Oct 18, 2010 at 2:31 PM
