2000 Cadillac STS Stability system
2000 CADILLAC STS
SAYCOLE23
2000 Cadillac STS Automatic
I continue to receive "service stability system" message, along with "traction control" and "abs" message, and I've had it at two garages and no one sees to be able to tell me what this message may mean. Can you please help me?!!!
Jun 10, 2010 at 9:05 AM
FACTORYJACK
  • 4,159 POSTS
Out of the two garages, has anyone pulled the codes? You can do this yourself, as your STS has on-board diagnostics. You can enter it by pressing info up, and on/off at the same time. After a few seconds of holding the buttons(with key on), all VF segments will light, and then your info display will read ALL? from here use the info button up or down to select ABS?, then press on/off. The message will change to ABS CODES?, press on/off again and record the code(s). Reply back with the results, and I might be able to offer some guidance.
Jun 10, 2010 at 2:03 PM
