Getting a ABS light and a service stabilty system message. Doesn't happen all the time.
Jan 20, 2010 at 10:56 AM
FACTORYJACK
✓Experienced Mechanic
If you press info up, and on/off, and hold them. It will enter diagnostics. Info up or down will scroll modules, on/off will execute. You want to navigate to ABS CODES? and press on/off. Read and report the codes. If it is a C1287, replace the steering wheel position sensor.
Jan 20, 2010 at 2:03 PM
BDIFE1
MEMBER
Thanks will give it a try
Jan 20, 2010 at 2:07 PM
