2000 Cadillac Seville Hesitation
VIPER2308
I have a 2000 Cadillac Seville STS with 130,000 miles on it.
After I drive it for about 40 minutes without stopping it starts to hesitate when I accelerate at low speeds and from rest. I am wondering what could be causing it.
Apr 11, 2007 at 9:20 AM
THE KIDD
[quote:4f2c073ad3="viper2308"]I have a 2000 Cadillac Seville STS with 130,000 miles on it.
After I drive it for about 40 minutes without stopping it starts to hesitate when I accelerate at low speeds and from rest. I am wondering what could be causing it.[/quote:4f2c073ad3]
Disconnect battery for 5 hours both terminals. PCM is the problem. Problem will be fixed.
Apr 17, 2008 at 4:43 AM
BUZZSAW
  • 1,198 POSTS
[quote:99985b4985="the kidd"][quote:99985b4985="viper2308"]I have a 2000 Cadillac Seville STS with 130,000 miles on it.
After I drive it for about 40 minutes without stopping it starts to hesitate when I accelerate at low speeds and from rest. I am wondering what could be causing it.[/quote:99985b4985]
Disconnect battery for 5 hours both terminals. PCM is the problem. Problem will be fixed.[/quote:99985b4985]
that doesnt work, do you have a ck engine lite on?
scan your codes, off and down on the mode button on your heater controls, at the same time, with the key in the on position, look in your message center for codes.... start there
Apr 17, 2008 at 5:22 AM
Suggested Repair
Do not rely on disconnecting the battery or assuming the PCM is bad. Check whether the check engine light is on, then retrieve codes with the key on by pressing Off and Down on the climate-control mode button at the same time and reading the message center.
Conversation Summary
A 2000 Cadillac Seville STS with 130,000 miles hesitates during low-speed acceleration and from a stop after about 40 minutes of continuous driving. One reply claimed a five-hour battery disconnect would fix a PCM problem. The expert said that does not work and advised checking for a check engine light and scanning codes through the climate controls and message center.
