1999 Cadillac STS overheats
CYCOBILLY
  • 1999 CADILLAC STS
Engine Cooling problem
1999 Cadillac STS V8 Front Wheel Drive 102000 miles
Has new radiator water pump thermostat cap, drive 30 or 40 miles then go up hill and the temp climbs hoses look good heater core seems ok
If its air how do you purge it thanks in advance
Friday, August 21st, 2009 AT 6:50 PM
FACTORYJACK
  • 4,159 POSTS
If it had air trapped, it would eventually have expelled it, the Northstar is pretty good at not trapping air. My guess is that you have a head gasket concern, or other possible internal leak. I would have the cooling system block tested for combustion gases.
Friday, August 21st, 2009 AT 11:11 PM
