1993 Cadillac STS overheating
TADAW33
  • 1993 CADILLAC STS
  • V8
  • FWD
  • 167,000 MILES
I have changed my thermostat but my engine coolant is still overheating why is this happening
Sunday, November 2nd, 2008 AT 8:44 AM
  • 109,885 POSTS
Hi:
This can happen for several reasons. First, are the cooling fans coming on when the car heats up? Also, has the radiator been flushed or rodded out? Many time the rad will develope corrosion over the years not allowing proper flow for the coolant. Also, make sure none of the rad hoses are collapsing when the car is hot. If they pinch off the flow it will overheat.
Let me know if this helps, or if you have other questions.
Tuesday, November 18th, 2008 AT 1:32 PM
