1995 Cadillac SLS
132,367 MILES • V8 • 2WD • AUTOMATIC
ALPHONSO MOBLEY
why when i start my car it runs rough but idles good after i let it run for a momment?
Mar 8, 2010 at 10:40 PM
FACTORYJACK
  • 4,159 POSTS
Could either be excess fuel in the intake system due to a leaking fuel pressure regulator, or coolant in the cylinders that accumulates after it cools due to internal leak. Pull the vacuum line to the regulator and check for presence of raw fuel. Monitor it for gradual coolant loss, it doesn't take much to cause a slight misfire, since it don't burn.
Mar 9, 2010 at 2:53 AM
