1998 Cadillac SLS engine
150,000 MILES • V8 • 2WD • AUTOMATIC
FREDERICK TERRY
engine running rough,shaking in park and driving eating alot of gas
Nov 27, 2009 at 6:57 AM
FREDERICK TERRY
[quote:883ef9ef0f="frederick terry"]Engine Mechanical problem
1998 Cadillac SLS V8 Two Wheel Drive Automatic 150000 miles
engine running rough,shaking in park and driving eating alot of gas[/quote:883ef9ef0f]
Nov 27, 2009 at 7:00 AM
FACTORYJACK
  • 4,159 POSTS
I would assume you have a check engine light as well. Press 'Info' up, and 'on/off' to enter diagnostics, use 'Info' to scroll alphabetically to PCM?. Press 'on/off' and then use info to get 'PCM codes?' and press 'on/off'. Record and report code(s). It sounds like you may have an ignition misfire. Could be a plug, wire, coil, or related.
Nov 27, 2009 at 1:24 PM
