1994 Cadillac Seville DTC 49 AIR Code
JJSFTC
I have a 1994 Cadillac Seville STS. I purchased it about w eek ago. IT has been dying on me while parked and driving. I hooked up a hand held computer and got these codes.
A.I.R. Management System Malfunction
DTC 49
I can't find what these mean. Can you tell me? When it dies I can usually let it sit about 15 minutes then it will start again. I think the problem is getting worse.
Nov 16, 2007 at 6:57 AM
MERLIN2021
  • 17,250 POSTS
air system is the air pump and any injection parts to the exhaust, it is a secondary system to burn unburned gases, If the pump freezes, or tubes rust out, code is set...
Nov 16, 2007 at 8:44 AM
BUZZSAW
  • 1,198 POSTS
[quote:2db80bf91d="jjsftc"]I have a 1994 Cadillac Seville STS. I purchased it about w eek ago. IT has been dying on me while parked and driving. I hooked up a hand held computer and got these codes.
DTC 49
I can't find what these mean. Can you tell me? When it dies I can usually let it sit about 15 minutes then it will start again. I think the problem is getting worse.[/quote:2db80bf91d]
the A.I.R. pump needs replacing and the diverter valve on the top of the back valve cover needs replacing for the 49 code, dont think this would cause a dieing prob just a ck engine lite,,,... any other codes?
Nov 30, 2007 at 2:10 AM
Suggested Repair
For DTC 49, replace the secondary air injection (A.I.R.) pump and the diverter valve on the rear valve cover, and inspect the related tubes for rust or blockage. Experts note this usually causes a check engine light and may not explain the stalling, so check for any additional codes if the engine continues to die.
Conversation Summary
The owner of a 1994 Cadillac Seville STS reports that the engine dies while parked or driving and usually restarts after about 15 minutes. A scan showed DTC 49, an A.I.R. management system malfunction. Experts explain that the secondary air system includes the air pump and exhaust injection parts, and recommend replacing the air pump and diverter valve. They say this typically sets the check engine light rather than causing the stalling and ask whether other codes are present.
