2001 Cadillac Seville Error codes!?!?!?!?
2001 CADILLAC SEVILLE
97,000 MILES • V8 • FWD • AUTOMATIC
LITO719
I got these codes today , P0507, P0386 , P0385, P0106. my car will not keep running its starts but will not stay on. i know 507 is a idle air control , and 106 is a manifold absolute code but what will i need to fix my car. I know i have to buy a new alternator but will that fix everything???? Pls help
Nov 17, 2009 at 3:18 PM
FACTORYJACK
  • 4,159 POSTS
It all depends on what is current and what is history. P0385/p0386 are crank sensor codes, these are usually synonymous with a stall at stops. If they are hard failures a starting issue may result. The idle air control valves aren't known for failing, the passage could be dirty.
Nov 18, 2009 at 1:58 PM
