1997 Cadillac Seville Engine is not preforming and is eatin
72,000 MILES • V8 • FWD • AUTOMATIC
CADILLAC MAN
Ever since fall of 2007 I have had starting issues with my car. When it is cold or hot, its fine. However, after being run then sitting for around an hour, it cranks for about 5 - 10 seconds before starting at a low bog. Then i noticed the coolant was dissapearing and I smelled anti - freeze in the front area and in the cab of the car. Had dye test preformed and came back good. And there are no puddles that i can find anywhere. My friend was fallowing me the other day and said there was white / blue smoke coming from my tail pipes if that is related at all. Even more recently, the car lost alot of power and shutters like it wants to stall. Especially going up hills or when i need that extra kick of power. Just replaced fuel filter hoping for a quick fix but no luck and it keeps getting worse. I love the car and so does my dad. I dont want to get rid of it, but is it really worth keeping with the repairs that need to be done with it. Thanks in advance for your time and helpfullness.
Mar 31, 2008 at 10:41 AM
  • 75,988 POSTS
When was the last time it seen a major tune-up?
Lets get the coolant temperatrue sensor and fuel pressure/exhaust system for restriction checked then report back.
Are you overheating and how often do you put oil in the crankcase?
Mar 31, 2008 at 1:57 PM
CADILLAC MAN
Overheats every once in a while.
Add oil about twice a month or more
I have no idea when the last tune up was, i bought the car less than a year ago...
Apr 1, 2008 at 7:04 AM
  • 75,988 POSTS
Get it block and pressure tested for the overheating problem and also have the fuel pressure checked-
Apr 1, 2008 at 8:27 AM
BUZZSAW
  • 1,198 POSTS
[quote:a6e4b793f2="rasmataz"]Get it block and pressure tested for the overheating problem and also have the fuel pressure checked-[/quote:a6e4b793f2]
spark plugs on this car are replaced at 100k, which I would also put on wires, the smoke out the tail pipe is just oil and carbon, the rings are sticking and need cleaned with a solution that cadillac knows about, they dump it in the cylinders and it cleans them it may also take a couple times. it works good
if you are smelling antifreeze you have a leak, places to look heater hoses, water pump, radiator, or heater( rub your hand on the carpet on pass side frt floor board and smell your hand) the coolant cristlizes so you may not see it unless its pooring out, never seen a head gasket leak coolant, it just overheats and blows it out the overflow jug
scan your codes for problems, off and warmer on the heater controls at the same time, with key in the on position, look at the IP for them, write them down and post them here!!! stalling may be due too crank sensors
as for the starting try a fuel PSI regulator its cheap 25 - 30 bucks and easy to install. its in the fuel rail on top of the motor, get it at the dealer, dont put thoes cheap parts on that car
not trying to scare you but you would be surprised on how many people keep driving there car even knowing its overheating, til it dies
Apr 3, 2008 at 8:45 PM
CADILLAC MAN
there are some history, but the only current one is MSM B2120
also, the OBD 2 code reader finds a hidden code that says "multiple cylander miss fire"
Apr 7, 2008 at 6:51 AM
BUZZSAW
  • 1,198 POSTS
[quote:9438d1f17f="Cadillac Man"]there are some history, but the only current one is MSM B2120
also, the OBD 2 code reader finds a hidden code that says "multiple cylander miss fire"[/quote:9438d1f17f]
I need the code # to help, multiple misfires I would start with wires and go from there, go to napa or the dealer for parts
Apr 10, 2008 at 11:15 PM
PHILLIP-V
FUK ALL THE BULL. YOU HAVE A BURNT VALVE. CAR IS RUNNING ON 7 pistons. THE GAS IS NOT BEING BURNT N IS GOING THREW THE EXHAUST N GETTING BURNT IN CADILIC CONVERTER CAUSING OVER HEAT. to replace that ul need two new gaskets, ur looking at 1200 dollars atleast. ive owned three different cadillacs two different engines
Jan 28, 2012 at 11:56 PM
  • 75,988 POSTS
Don't come in here with that attitude its uncall for and might cause you to get 86 from here
How did you know its a burned valve running on 7 pistons?
Jan 29, 2012 at 12:13 AM
CADIEMAN
  • 3,544 POSTS
gees buddy go to another site with that.white smoke tells me that coolant is in the cylinders.pick up a hydocarbon test to check the coolant for signs of a leak in the engine.poss.leaking intake or head gasket.u can pull all the plugs and check the plugs for signs of coolant on them.
Jan 29, 2012 at 9:55 AM
