1994 Cadillac Seville about car not starting
DADDY1
  • 1994 CADILLAC SEVILLE
  • V8
  • FWD
  • 197,000 MILES
I have a problem and that is that when I put the key into the ignition it won't start but all the light's and stuff work just fine
Wednesday, February 18th, 2009 AT 12:25 PM
FACTORYJACK
  • 4,159 POSTS
Does it turn over/crank, or no starter engagement at all? If it does not crank, there is a connector stuffed down behind and to the left, of the p.S. Pump. It has a larger gauge purple wire that is the signal wire to the starter. Disconnected, you can check that a signal is present on the harness end, when you turn the key to start or, you can feed 12v to the starter and see if it engages. A test light will accomplish the first test, a fused jumper wire is recommended for the second.
Wednesday, February 18th, 2009 AT 9:50 PM
