1994 Cadillac Seville
YELDARB1980
  • 1994 CADILLAC SEVILLE
how do I remove the ignition I replaced the steering colomn and it has the passkey could I put the old ignition back in or what all do I have to put in that would work for the car to start
Monday, September 7th, 2009 AT 2:25 PM
FACTORYJACK
  • 4,159 POSTS
If you have the key from the original column, you could have it interrogated at a dealer to determine it's VATS value. Then you just need to have a key cut the same as the replacement column, but in the VATS pellet value as the original.
Tuesday, September 8th, 2009 AT 11:01 PM
