1991 Cadillac Seville fan relay module
1991 CADILLAC SEVILLE
14,400 MILES • V8 • FWD • AUTOMATIC
BLACK5811
i have changed the fan motor and the temp sensor and three relays under the hood.
i do not no where to look for the fan control module.
or the fan relay module.
1991 cadillac seville 4.9 ltr engine.
where is this located so i may swap it out and then maybe my fan motor will start turning and keep car from over heating.
thanks.
D.Black
May 12, 2008 at 6:02 AM
BUZZSAW
  • 1,198 POSTS
[quote:5a695cf6b5="black5811"]Engine Cooling problem
1991 Cadillac Seville V8 Front Wheel Drive Automatic 144,00 miles
thanks.
D.Black[/quote:5a695cf6b5]
the computer turns on the fans through voltage of the cooling temp sensor, ck your fuses and fusiable links there where the relays were, up on the firewall behind the plastic sheild. I can give you a wiring diagram but I need your e-mail to send it
May 13, 2008 at 4:31 AM
