Disconnecting the V8-6-4?
1981 CADILLAC SEVILLE
75,000 MILES • V8 • FWD • AUTOMATIC
FINAJET99
HI, I have read here about making this vehicle run on 8 all the time, but am unclear which wires to disconnect...... I have read the ones on the valve covers... and one other place that I can't remember.... can someone be more specific on where these wires are.... an info is appreciated...
Aug 5, 2008 at 3:21 PM
FINAJET99
Thanks for your help.... after disconnecting the wires on the valve covers, seemed to be fine, but a few days later, while driving a short distance, it began to stall, like before, but not nearly as bad..
Cleared the codes last time, and here is the codes..... last time I did not do the engine codes...
Still get 25
Engine
1-10
2-99
3-99
4-68
5-70
6-0
7-46
8-0
9-2
10-0
11-2
If you can help with this I greatly appreciate it.... hope all those numbers doesn't mean lots of major things...
Thanks,
Earl
Aug 16, 2008 at 11:54 AM
2CARPRO JACK
  • 11,533 POSTS
Need to unplug the big connector on the trans, and plug in the wires on the valve covers. Disconnect the battery for a few minutes to clear the codes and drive it to see what comes back. You are probably setting codes for the actuators not being plugged in. My software doesnt even go back that far (81) for the codes.I just know the 4-6-8 was junk on the showroom floor as far as operation went, and unhooking the trans connector solved almost every problem the car had as far as driveability went.The car was ok, they just didnt quite get that system right. When it stalls, check it for spark and fuel pressure to see what is missing. it start right back up?
Aug 17, 2008 at 1:27 AM
