Fast Coolant Consumption
CADILLAC
CDUB
I have a 99' SLS, V8, 4.6 northstar engine with a 102K on it. Everything has been fine since I bought it (6 months ago) but now it is sucking down the coolant. I have had to replace the coolant three times in about 2 months... The engine still has power, sounds fine and does not overheat so I am puzzled. I do not know what is happening... I would be very greatful for any help/advice with this situation.
May 24, 2007 at 9:51 AM
  • 75,988 POSTS
[quote:8805850619="Cdub"]I have a 99' SLS, V8, 4.6 northstar engine with a 102K on it. Everything has been fine since I bought it (6 months ago) but now it is sucking down the coolant. I have had to replace the coolant three times in about 2 months... The engine still has power, sounds fine and does not overheat so I am puzzled. I do not know what is happening... I would be very greatful for any help/advice with this situation.[/quote:8805850619]
If it ain't leaking then its being burn in the combustion chamber. Check the oil level and color also the transmission level/Color.
May 24, 2007 at 7:08 PM
