1999 Cadillac Seville Coolant Loss
CADILLAC
CDUB
I have a 99' SLS, V8, 4.6 northstar engine with a 102K on it. Everything has been fine since I bought it (6 months ago) but now it is sucking down the coolant. I have had to replace the coolant three times in about 2 months... The engine still has power, sounds fine and does not overheat so I am puzzled. I do not know what is happening... I would be very greatful for any help/advice with this situation.
May 24, 2007 at 9:51 AM
  • 75,988 POSTS
[quote:8805850619="Cdub"]I have a 99' SLS, V8, 4.6 northstar engine with a 102K on it. Everything has been fine since I bought it (6 months ago) but now it is sucking down the coolant. I have had to replace the coolant three times in about 2 months... The engine still has power, sounds fine and does not overheat so I am puzzled. I do not know what is happening... I would be very greatful for any help/advice with this situation.[/quote:8805850619]
If it ain't leaking then its being burn in the combustion chamber. Check the oil level and color also the transmission level/Color.
May 24, 2007 at 7:08 PM
Suggested Repair
If there is no external coolant leak, suspect coolant is being burned in the combustion chamber. Check the engine oil level and color, and also check the transmission fluid level and color.
Conversation Summary
The owner of a 1999 Cadillac Seville SLS with a 4.6L Northstar reports rapid coolant loss over about two months, with no overheating or loss of power. The expert says that if the coolant is not leaking externally, it is likely being burned in the combustion chamber, and advises checking the oil level and color as well as the transmission fluid level and color.
