1997 Cadillac Sedan de Villle Turn Signal Flasher
1997 CADILLAC
JANIE
I know it's a dumb question but my turn signals come on but will not flash. I understand the flasher needs to be replaced but I can't find the darn thing. I found the one for the hazard lights but not the turn signals. Can you tell me where it is? Also, my ABS brake light and traction control lights come on intermittently. The traction control is engaged when this happens but there is no need for it, no rain or snow or anything. Got a clue why this happens? I can use any help. Thanks!
Jul 24, 2006 at 1:12 PM
MIKEYBDMAN
  • 623 POSTS
[quote:8f8356efcb="JANIE"]I know it's a dumb question but my turn signals come on but will not flash. I understand the flasher needs to be replaced but I can't find the darn thing. I found the one for the hazard lights but not the turn signals. Can you tell me where it is? Also, my ABS brake light and traction control lights come on intermittently. The traction control is engaged when this happens but there is no need for it, no rain or snow or anything. Got a clue why this happens? I can use any help. Thanks![/quote:8f8356efcb]
The flasher is located Behind Instrument Panel LH Of Steering Column. Also, make sure all of your turn light bulbs work. The flashers will light the lights a steady light whenever you have a bulb out. So before you replace the flasher, check all of the lgiths and make sure they all work.
Jul 24, 2006 at 1:34 PM
