1989 Cadillac Fleetwood Intermittent Heat
MARCUS89CADI
MY 89 CADILLAC FLEETWOOD WITH 103522 MILES RECENTLY STARTED HAVING A HEAT PROBLEM. WHEN I START IT FOR THE FIRST TIME OF THE DAY AND LET IT IDLE ITS FINE. BUT WHEN I START MOVING IT BLOWS COLD AIR. AND THEN ITS INTERMITTEN THROUGHOUT THE RIDE. BUT MOSTLY COLD. IT SEEMS LIKE WHEN I PUSH THE GAS IT GETS WARM BUT NOT ALL THE TIME SO I REALLY DONT KNOW.
Oct 10, 2007 at 3:01 PM
SERVICE WRITER
  • 9,123 POSTS
Make sure the coolant is full. Sounds like it is just low coolant (maybe a leak). When the coolant level drops, the first area to lose out is the heater core. When the engine is reved ,the coolant can get forced into it enough to circulate into the heater core and give temporary or intermittant heat. So lets start there.
Oct 10, 2007 at 9:35 PM
Suggested Repair
Check that the coolant is full and look for a leak. Low coolant often leaves the heater core dry first; higher engine speed can temporarily force coolant through and produce intermittent heat.
Conversation Summary
The owner of a 1989 Cadillac Fleetwood reports intermittent heat: it is fine at the first idle of the day, then mostly blows cold while driving and sometimes warms when accelerating. The expert recommends starting by confirming the coolant is full, because low coolant, possibly from a leak, can starve the heater core until engine speed forces circulation.
