CLEAN4U
1990 Fleetwood Cadi, Fwd, 4.5, 90,000.
Code E49 is what keeps coming up. New plugs, dist, cap, rotor, pcv, wire fine, egr fine, replaced air charge sensor, replaced 02 sensors,replaced one injector,egr fine, still rough idle.
How can I run a test manually for the air injection pin point the test I need to do? I have the Chit. Man. but can 't find it anywhere. HELP{!!!Thank you :roll:
Sep 22, 2007 at 11:10 AM
BUZZSAW
  • 1,198 POSTS
[quote:4d08f4d072="clean4u"]1990 Fleetwood Cadi, Fwd, 4.5, 90,000.
How can I run a test manually for the air injection pin point the test I need to do? I have the Chit. Man. but can 't find it anywhere. HELP{!!!Thank you :roll:[/quote:4d08f4d072]
I belive the e49 code is that diverter valve on back valve cover the big one, the A.I.R. pump is comming apart and putting debri in valve, make sure what the code is first, I have a 90 or 91 caddie manuel in my tool box
Sep 24, 2007 at 5:53 PM
COCOCHANELS
Who knows where to download XRumer 5.0 Palladium?
Help, please. All recommend this program to effectively advertise on the Internet, this is the best program!
Jun 25, 2009 at 9:25 PM
COCOCHANELS
no any cracks(((
Think, XRumer 5.0 Palladium is really BEST software for promo and for SEO!
Jul 21, 2009 at 1:35 AM
