2002 Cadillac EL Dorado How to clear or fix code 1312
JOINTDOC
  • 2002 CADILLAC ELDORADO
  • V8
  • FWD
  • 65,000 MILES
A/C not working on 2002 Eldo. A retired mechanic played with the buttons and got an error code 1312 which appears to mean High Side Temp Sensor Open Circuit.
How do I find this sensor, can I replace or fix it myself?
How do I use the AC controls to find codes and clear them?
If I clear the code, how do I add Freon myself?
Bob G
Thursday, July 16th, 2009 AT 8:08 PM
FACTORYJACK
  • 4,159 POSTS
The temp sensor is in the high side line, by the plastic clip that holds the line down near the center firewall. It may or may not be a sensor, it could be wiring. You should have 5 volts on one wire, and the programmer grounds the other. Both the low temp, and high temp are the same and can be switched to see if fault follows sensor. I don't recommend or endorse adding freon yourself, if you have to ask how. It is dangerous, and can cause more problems with the system if done improperly. A parts store might sell you the do-it-yourself kit, though. Clearing/reading codes-push off and passenger warmer until a segment check displays, and codes follow. Fan down will scroll modules and options, fan up will select. Go to ACM, or ACP clear codes.
Thursday, July 16th, 2009 AT 11:52 PM
