1998 Cadillac El Dorado Rear Air Suspension
1998 CADILLAC ELDORADO
103,000 MILES • V8 • FWD • AUTOMATIC
VDANIELE
The air line going to the right rear shock had rubbed and was leaking, the pump ran all night and killed the battery. I fixed the line, but now the pump continues to run and the rear of the car is as high as it can go and rides like a truck! How do I reset the suspension pump to be normal and stop running constantly?
Feb 26, 2010 at 5:57 AM
SCOTTY DEE
  • 592 POSTS
The suspension control module may have failed and is keeping the system running continuously. The CVRSS needs to scanned for any trouble codes first and foremost. Let me know what the codes are and I can tell you how the test procedure works.
Feb 26, 2010 at 7:52 AM
