1993 Cadillac El Dorado Engine turns, but doesn't start
166,800 MILES • V8 • FWD • AUTOMATIC
TJAXXX
I have a 1993 Cadillac Eldorado. It's in great condition, runs well. When I try to crank the car, the engine turns but it will not start. I recently replaced the Map sensor and that seemed to take care of the problem. Then I replaced the battery and the problem started again. The fuel pump works, I have replaced the fuel filter and there is fuel getting through the hose. The fuel injectors were recently cleaned with Lucas (I did a loop around the interstate to run it through). There is fire from the coil pack and the spark plugs were just replaced a week ago. The wires are in good shape and connected. I also reset the security system after replacing the battery in case the anti-theft device was activated when the battery was replaced. Have I gotten a hold to some bad gas? Or is there a problem with the ignition switch? I'm at a loss!
Feb 9, 2008 at 1:03 PM
  • 75,988 POSTS
I have replaced the fuel filter and there is fuel getting through the hose. This is not enough give me some fuel pressure readings with a pressue gauge so I can continue to help
Could be the injectors are not being energized-
Feb 9, 2008 at 5:13 PM
BUZZSAW
  • 1,198 POSTS
[quote:a59c4967d4="tjaxxx"]Engine problem
1993 Cadillac El Dorado V8 Front Wheel Drive Automatic 166800 miles
I have a 1993 Cadillac Eldorado. It's in great condition, runs well. When I try to crank the car, the engine turns but it will not start. I recently replaced the Map sensor and that seemed to take care of the problem. Then I replaced the battery and the problem started again. The fuel pump works, I have replaced the fuel filter and there is fuel getting through the hose. The fuel injectors were recently cleaned with Lucas (I did a loop around the interstate to run it through). There is fire from the coil pack and the spark plugs were just replaced a week ago. The wires are in good shape and connected. I also reset the security system after replacing the battery in case the anti-theft device was activated when the battery was replaced. Have I gotten a hold to some bad gas? Or is there a problem with the ignition switch? I'm at a loss![/quote:a59c4967d4]
squirt some carb cleaner down the throttle plates, while someone turns it over, if it starts its fuel, if it doesn't its spark
ck for codes, off and warmer on the heater with the key in the on position. write them down and post them here
Feb 11, 2008 at 3:39 AM
