1992 Cadillac EL Dorado Car wont start rolls in park
JERRY1103
  • 1992 CADILLAC ELDORADO
  • V8
  • 120,000 MILES
My parents have an Eldorado they pulled in the garage put the car in park and turned the car off the car started to roll they set the ebrake and tried to start the car it will not start in park or in neutral. All the lights come on like normal bu the engine does not turn over.
Pleas and thanks for your help!
Jerry
Saturday, July 12th, 2008 AT 1:20 PM
DOCFIXIT
  • 18,828 POSTS
Probably the shift selector out of adjustment. Look on the transmission for the shift cable and where it is attached. That is the switch neutral safety When in neutral the lever lines up with I believe a small hole. If off adjust linkage. Just to see move shifter from neutral to D see if it starts. If is does then it needs attention.
Hope this will help
Saturday, July 12th, 2008 AT 1:39 PM
