Have someone move the steering wheel a little each way, while you look at the sterring box. If you see play in the box it can be adjusted by the set screw with a nut on top, loosen the locking nut while holding the screw in place, tighten the screw a little to see if the play stops DO NOT OVERTIGHTEN, if you do the steering will bind up. After adjusting the
screw re tighten the locking nut, make minor adjustments to the steering box, until the play is removed, check the steering after you have completed the adjustment.
SPONSORED LINKS
Thursday, March 22nd, 2007 AT 8:18 AM
