I have a 1993 caddilac devill and it is leeking coolant ive
1993 CADILLAC DEVILLE
CHRISPY
I have a 1993 caddilac devill and it is leeking coolant I have put a new raditor in it and it still leaks and i cant find it it is on the side that the water pump is on but i cant find it can you help me?
Nov 12, 2006 at 6:10 AM
UNCLEWOOTSIE
  • 40 POSTS
it could be the water pump itself ,you need to pressure test the system (or) start the vehicle and get under it to see where the leak is (but make sure it,s secure before you get underneath it
Nov 13, 2006 at 10:10 AM
CHRISPY
Hey thanks guys I replaced the water pump and the thrmostat , and then i found the leak!!! I't was comeing from a( hot water metal line) thats goes to the heater core and it's in a tiet spot its at the front or the car and it runs behind the A/C compressor. Thanks this is the most info. on cars that I have got from the internet .
Nov 13, 2006 at 2:51 PM
