Ford Windstar 2002
ROBERTEB
Ford Windstar, 2002, 81000 miles, 3.8 engine
Odometer light flickers occasionally, and periodically speedometer-cluster gauges will malfunction, gas and temperature gauges will go to "off" position, and tack and speedometer will go to wide-open position. Any suggestions, please?
Sep 8, 2007 at 7:07 AM
2CARPRO JACK
  • 11,533 POSTS
Check for any loose connections or corrosion at the fuse block underhood.Might be a bad connection behind the cluster, try removing it and look at the connections for any looseness or corrosion
Sep 9, 2007 at 1:14 AM
