2002 Ford Windstar Gauge Cluster Issues
ROBERTEB
Ford Windstar, 2002, 81000 miles, 3.8 engine
Odometer light flickers occasionally, and periodically speedometer-cluster gauges will malfunction, gas and temperature gauges will go to "off" position, and tack and speedometer will go to wide-open position. Any suggestions, please?
Sep 8, 2007 at 7:07 AM
2CARPRO JACK
  • 11,533 POSTS
Check for any loose connections or corrosion at the fuse block underhood.Might be a bad connection behind the cluster, try removing it and look at the connections for any looseness or corrosion
Sep 9, 2007 at 1:14 AM
Suggested Repair
Check the underhood fuse block for loose connections or corrosion. Remove the instrument cluster and inspect the rear connections for looseness or corrosion.
Conversation Summary
A 2002 Ford Windstar with 81,000 miles and a 3.8 engine has an odometer light that flickers, and the cluster gauges sometimes fail: fuel and temperature gauges drop to off while the tachometer and speedometer swing wide open. The expert suggested checking the underhood fuse block and the connections behind the cluster for looseness or corrosion.
