engine overheats
BOBGEORGE091475
93 deville bout 180k miles, new thermostat & water pump. radiator has a minor leak. engine over heats to the point where the stop engine temp light comes on and there is clouds of white smoke coming from the engine. is it my radiator that is the cause of all of this? or is there something else?
Aug 4, 2007 at 2:34 PM
  • 75,988 POSTS
clouds of white smoke coming from the engine. Where within the engine or its coming out of the exhaust?
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck. This will rule out the headgasket,block & cylinder head.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Aug 4, 2007 at 4:04 PM
BOBGEORGE091475
i can take the oil cap off and smoke will come from there...
Aug 5, 2007 at 7:22 AM
  • 75,988 POSTS
[quote:ca522a7824="bobgeorge091475"]i can take the oil cap off and smoke will come from there...[/quote:ca522a7824]
You getting me twisted here-confirm the color is it bluish or whitish I need to know this before we proceed.
It could be the headgasket,block/head or a clogged-up crankshaft ventilation system
Aug 5, 2007 at 12:06 PM
