i have a 1994 cadillac deville. 138.000 miles, 4.9 liter. i have a new water pump and new radiator....after the new radiator was installed the car will run about 10 minuters and starts overheating.....it did not do this with the old radiator which was leaking.....they checked the thermostat and said it was good .....they said its probably my headgasket.....but it had no symptoms for a head gasket problem......could the install have been flawed??if its a head gasket is their a sealant than can be used to repair it?........ i have donated 2 dollars as i am on a fixed income and cant afford any more.......thank you anthony zumpano............tonyzump@roadrunner.com
Nov 29, 2007 at 2:46 AM
