1984 Cadillac Deville Stalls When Cold
LOWCADIRIDER
i have 84 cadillac de ville with 4.1 engine the new engine has 60,000 miles and transmition was just rebuild, i had the car parked for a year and before i started to drive it again i changed sparkplugs and sparkplug wires, fuel filer air filer and drained the gas tank but after 2 month of driving the engine started acting up, its starts with no problems but i have to wait for a while for it to warm up before i can put it in drive and if i dont wait it sounds like its about to die and few times it died but started back up also it feels like it has almost no power i tryed T.B.I. cleaner but it did not help do you think it can be EGR valve because i dont think it was ever changed when engine was replaced and the car had 170,000 before the new engine was put it, i ran computer for any error coded and it didnt show any
Aug 24, 2007 at 9:36 PM
  • 75,988 POSTS
[quote:d32bcf39d7="lowcadirider"]i have 84 cadillac de ville with 4.1 engine the new engine has 60,000 miles and transmition was just rebuild, i had the car parked for a year and before i started to drive it again i changed sparkplugs and sparkplug wires, fuel filer air filer and drained the gas tank but after 2 month of driving the engine started acting up, its starts with no problems but i have to wait for a while for it to warm up before i can put it in drive and if i dont wait it sounds like its about to die and few times it died but started back up also it feels like it has almost no power i tryed T.B.I. cleaner but it did not help do you think it can be EGR valve because i dont think it was ever changed when engine was replaced and the car had 170,000 before the new engine was put it, i ran computer for any error coded and it didnt show any[/quote:d32bcf39d7]
Check these two out-PCV and EGR valves their partners in headaches relating to stalling and rough idle. Not them-Try checking the fuel pressure for a start.
Aug 24, 2007 at 10:06 PM
Suggested Repair
Check the PCV and EGR valves for stalling and rough idle. If they are not the cause, check fuel pressure.
Conversation Summary
A 1984 Cadillac Deville with a 4.1 engine starts fine but nearly stalls or dies if driven before warming up and has little power. No computer codes were found, and throttle-body cleaner did not help. The expert advised checking the PCV and EGR valves, then fuel pressure if those are not the problem.
