1991 Cadillac Deville Dies on Ramp
BLAZINJ
1991 sedan deville 4.9 auto 111,000 its wierd every time i go to get on a on ramp to the thruway my car jus dies out and i tap the gas a few times and she picks up and goes i got the codes of the computer and it gave me e48 which is the egr valve so i replaced that but still has the code in memory and also the code e85 which is idle throttle angle to high do have any suggestions on these codes and y it would die out then take off after pumping the gas i would appreciate this alot thanks so much
Oct 22, 2007 at 3:35 AM
BUZZSAW
  • 1,198 POSTS
[quote:d582a647d6="blazinj"]1991 sedan deville 4.9 auto 111,000 its wierd every time i go to get on a on ramp to the thruway my car jus dies out and i tap the gas a few times and she picks up and goes i got the codes of the computer and it gave me e48 which is the egr valve so i replaced that but still has the code in memory and also the code e85 which is idle throttle angle to high do have any suggestions on these codes and y it would die out then take off after pumping the gas i would appreciate this alot thanks so much[/quote:d582a647d6]
look down the throat of the throttle plates, carbon causes this, the tubes at the bottom are clogged and the TPS is outa wack, this stuff needs cleaned out and an Idle set up needs to be preformed
Oct 29, 2007 at 3:41 AM
Suggested Repair
Inspect the throttle plates for carbon buildup and clean the clogged tubes at the bottom of the throttle body. Check and correct the throttle position sensor, then perform a proper idle setup. Clear stored codes after repairs and recheck.
Conversation Summary
A 1991 Cadillac DeVille with the 4.9 engine dies when accelerating onto a highway ramp, then recovers after the gas pedal is tapped. Stored codes include E48 for the EGR valve, which was replaced but remains in memory, and E85 for idle throttle angle too high. The expert says carbon in the throttle body, clogged lower tubes, and an incorrect TPS setting can cause this and recommends cleaning those areas and performing an idle setup.
