Easy test to do.
Turn on your headlights.
With someone looking at your headlights, try to start the car. If your headlights do not dim, then it means that your starter is either no good, or you have a broken connection in the fuseable link. A fuseable link wire acts like a fuse. When overheated, whether it be internal or external, the connection may break internally. The wire may look good from the outside and that's where most people are fooled and many mechanics make a home run in billing the customer, they charge the customer for a new starter when really all they replaced was a 2$ fuseable link.
I hope this solved your problem, Let me know.
Jun 12, 2020 at 4:30 AM
(Merged)
