2001 Cadillac Deville sudden engine or electrical failure w
70,000 MILES • V8 • 2WD • AUTOMATIC
CYNTHIA T COMER
My car will suddenly quit running, the dash lights go out, no power at all, while driving . I can be driving down the Interstate with my foot on the accelerator and it will cut off, or taking offfrom a dead stop, coasting, changing gears, or at any time and the car will suddinly just quit running. I have no power steering or control of the car. I can put the car in neutral and start, or stop fully and put it in park and start it.The mechanic has connected it to a computer while running and cannot get it to simulate the problem. Do you have a diagnosis?
Dec 17, 2009 at 1:01 PM
FACTORYJACK
  • 4,159 POSTS
It is possible that you have a failing ground cable from the alternator mounting bolt to the frame rail. This may be influenced at times by engine motion, and possibly a broken front engine mount allowing to lift and stress the cable. Or the cable could be loose. It is viewed at the right front corner of the engine compartment.
Dec 17, 2009 at 2:11 PM
