Chances are we won't be hearing from that person, it was back in September and they never brought closure.
So your Deville occasionally won't start. First be certain that the key is not being rolled to start too quickly. It takes a second or two for the theft to validate. The next check would be, when the fault occurs, to be checking the start signal wire to see if a signal is being sent. If there is a signal and it won't turn over, it needs a starter. It would also be a good idea to check codes, and see if there are any in history that may relate.
Wednesday, February 3rd, 2010 AT 8:16 AM
