2001 Cadillac Deville how much??
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
DLOEM1
how much does a transmission mount run and about how much to put it on
also a mass air flow sensor how much and how much to put it in??
Feb 5, 2010 at 1:35 PM
FACTORYJACK
  • 4,159 POSTS
Which mount are you talking about? The one that usually fails is the front engine mount, symptom of clunk on accel forward. That mount is about 1.5 hours flat rate to replace, and I think the mount runs $150 to 170.
I am showing the MAF sensor at about $235 for part, and less than .5 hrs to replace. A note on it, you might check and see if there is a software calibration upgrade to address a P0101 MAF code setting prior to replacing it. You dont see too many of them fail.
Feb 5, 2010 at 4:47 PM
DLOEM1
just seeing if its worth the investment
Feb 5, 2010 at 4:51 PM
DLOEM1
thank you and also another question i have a buick lesabre i want to replace the ignition switch and reprogram a new key how much do you think it will run me.......the ignition is no longer reading the key
Feb 5, 2010 at 4:53 PM
FACTORYJACK
  • 4,159 POSTS
What year?
Feb 5, 2010 at 5:27 PM
