Before investing, is this just for maintenance or is there a problem?
Not really much you can do for a tune up. Replace the spark plugs if they are original. Replace the fuel filter, clean the throttle plate, check/replace the air filter, and replace the fuel filter if it has been some time. Also a good time to check/replace the cabin air filter. There is no adjustments or settings that can be made.
Thursday, May 27th, 2010 AT 11:40 PM
