2001 Cadillac Deville dash board repair
131,000 MILES • V8 • FWD • AUTOMATIC
LARRYD1352
Hello
I have a 2001 Cadillac Deville and the padded dash cover curling up in the middle and on the ends. Can this be replaced and if so where can I purchase and how do I remove the old one?
Thank you for your help
Larry
Nov 14, 2009 at 7:34 AM
FACTORYJACK
  • 4,159 POSTS
You could get a new one at a dealer, cost over $500 I believe. Possibly a salvage yard, if it hasn't been destroyed by airbag deployment, and the color is correct. I have repaired them with some good glue and clamps and stuff. to get it out, the dash vent deflectors and the defroster grille need removed, there are screws under each vent, and three across the top. Lift to disengage the clips at the cluster bezel, and remove both a-pillar trim pieces.
Nov 15, 2009 at 4:27 AM
LARRYD1352
Thank you so much for your help and hope you have a great weekend.
Larry
Nov 15, 2009 at 5:17 AM
